tranny fluid
tranny fluid
what type of oil should i run in my automatic transmission? truck is an 07. wasnt sure if its different then the older years and my search only brought up info on older trucks.
Max ATF is a synthetic, high-performance, automatic transmission fluid. Its low co-efficient of friction and high film strength help to dramatically reduce heat and wear. Additionally, Max ATF is more oxidation stable than other transmission fluids for longer fluid life.
Max ATF is recommended for a wide variety of transmissions. See our transmission lubricant cross reference chart for specific applications.
Automatic transmissions generate a great deal of heat and depend upon the transmission fluid for cooling and protection. More than 90 percent of all automatic transmission failures are caused by overheating; a 20°F reduction in fluid temperature can double the life of the transmission (Source: Perma Industries, Inc.). Max ATF significantly reduces heat to extend the life of your transmission.
Max ATF is fully compatible and can be mixed with other automatic transmission fluids; however, for the best results drain or flush the current oil and then fill with Max ATF.
Max ATF is recommended in vehicles requiring any of these automatic transmission fluids:
Allison C-4 KIA SP-II & SP-III
Allison TES-295 MAN 339F
Audi G-052-025-A2 Mercedes Benz 236.x
BMW LA2634 Mitsubishi Diamond SP-II
BMW LT71141 Mitsubishi Diamond SP-III
Chrysler ATF+, ATF+2 Nissan Matic-D
Chrysler ATF+2 Type 7176 Nissan Matic-J
Chrysler ATF+3 Nissan Matic-K
Chrysler ATF+4 Toyota Type-T
Ford Mercon Toyota Type T-III
Ford Mercon V Toyota Type-IV
GM 9986195 Voith 1161521 & 1161540
GM Dexron Voith 55.6335.32 (G607)
GM Dexron-II Voith H55.6336.33 (G1363)
GM Dexron-IID VW TL52162
GM Dexron-IIIG and H ZF TE-ML 14B
Honda ATF-Z1 (except in CVT's) ZF TE-ML 16L
Hyundai SP-II & SP-III ZF TE-ML 17C
JWS 3309
Please note: Max ATF is not recommended or an approved warranty replacement for: Ford Type F, Ford Mercon SP, Ford Mercon LV, GM Dexron VI, Mercedes Benz NAG-2, Toyota WS, Volvo 5 speed. Max ATF is not recommended for use in any CVT applications.
Dexron® is a registered trademark of General Motors Corporation. Mercon® is a registered trademark of Ford Motor Company.
JWS 3309
If you don't have a manual, you can download one from www.motorcraftservice.com. In the owners manual section. Other docs there too and it is free.
