Tranny shivering
Old Apr 5, 2008 | 08:25 PM
krazyballer's Avatar
Tranny shivering
Alright this is kind of hard to explain to bare with me, When in in about 3 gear and the rpms are low the truck will start to stumble even if i put my foot to the floor it will stumble then down shift then run fine. Its weird i checked the tranny fluid its fine not burnt ( i might replace it anyways). Once the rpms get higher it will run fine. I have a E4OD tranny, any ideas?
Old Apr 6, 2008 | 10:02 AM
anyone?
Old Apr 6, 2008 | 10:34 AM
You have to figure out if it's the tranny or an engine miss.
Old Apr 6, 2008 | 11:08 AM
How can one tell the difference? Also it does have a rough idol.
Old Apr 6, 2008 | 02:23 PM
Tune it up.
Old Apr 6, 2008 | 02:43 PM
Well less than a 1000 miles ago i put in auto lite double platinum plugs, plug wires, rotor, cap, fuel filter,air filter,new iac and some fuel injecion cleaner.
Old Apr 6, 2008 | 04:03 PM
Did you route the plug wires exactly as prescribed? If not, you could be getting inductive crossfire. Did you use any dielectric grease in the wire boots at both ends?
Old Apr 6, 2008 | 04:24 PM
Yep routed them exactly as they came off and i used dielectric grease on the boots and plug's and antiseeze on the threads. Im stumped im probably going to bring it into my ford mechanic teacher.
Old Apr 6, 2008 | 04:46 PM
You might want to do a compression test - you may have some burned valves.
Old Apr 6, 2008 | 05:44 PM
Well sometime this week i am going to replace the egr valve and tube and see if that solved it then i ill do a compression check.
