Overdrive Turned Off?
Old Jan 26, 2008 | 10:52 PM
artichoke's Avatar
Hello,
97 F150 w/ 4r70w, 90k
I was going up a steep grade, it was really snowy and icy so I turned on 4WD high and the OD off (light on) to keep it from shifting into overdrive. I was doing about 30 mph and after about 2 miles, the truck shifted into a higher gear which felt like overdrive (rpms dropped) and then the light on the stalk started blinking. It did not function normally until I stopped and restarted the truck later in the day. Do you know what could cause this?
Old Jan 27, 2008 | 08:02 AM
projectSHO89's Avatar
Pull the fault codes.
Old Jan 27, 2008 | 11:56 AM
LastSplash's Avatar
Sounds like the transmission got hot and went into "fail safe" mode, in which the transmission stays in D (3rd) for maximum cooling and the OD light blinks indicating a problem.
30mph in 4h up a steep grade was probably enough resistance to keep the transmission in 2nd gear which makes transmission hot.
Old Jan 27, 2008 | 01:19 PM
artichoke's Avatar
Thanks for the replies, I will get the codes pulled and see what's up. Thanks for letting me know what might cause this as well...
Old Mar 4, 2008 | 11:35 PM
artichoke's Avatar
Update...finally...
Well, I finally had the dealership pull the fault codes and I had a B1832 Shift Motor Intermittant Fail code. They recommended a new Shift Motor. Does this seem like it would cause the transmission to downshift? I'm certain it was still in 4wd. Also, I recall this past summer I was pulling a small boat up a hill and the same thing happened in 2wd. I'm thinking the two issues are not related. What do you think?
