binding 3 on the tree
Old Jan 5, 2008 | 07:29 PM
78ab's Avatar
Seems to be binding in the actual column. Going from 1st to 2nd, 3rd is ok, but coming back down into 1st, reverse is really tougho. Any ideas?
Old Jan 5, 2008 | 09:28 PM
subs1000w's Avatar
if i had to guess i would say i bushing is badly worn or had broken and fallen out but i have really no idea since i dont own nor have i ever driven a 3 on the tree but if i were you i would post this question over here
http://www.ford-trucks.com/forums/index.php
they have sections for the older trucks i assume yours is a 60s or 70s you would have better luck over there you could probobly just search and find your answer good luck
Old Jan 5, 2008 | 10:59 PM
78ab's Avatar
thanks!, I'll give it a try EDIT:Found a fix already by searching. THANKS!
