'94 Auto to 88 5-speed swap?
I have a donor '94 with auto (I believe it is A4OD or E4OD- it has the OD button) and my daily driver '88 5 speed. They are both 4x4, but the 94 has a 351 and the 88 has a 302. Will the tranny swap with current bellhousing, driveshaft, transfer case etc? And is it possible to get a floorshifter for it?
Thanks guys
Thanks guys
Same bell housing, and transfer case. Holes for the M5OD-R2 crossmount are in the frame.
One thing you will need to get is a 351 flywheel from a F-250 or 350. The 302 flywheel will not work.
What are the cab and bed configurations of both trucks?
Adrianspeeder
Adrianspeeder
Yeah I want to go manual to auto. The '94 is an extended cab short bed and the '88 is a reg cab longbed. As far s wiring nightmares- would it be better to find an AOD- same questions as before as far as hooking it up.
Ahhh, my bad, read it too quick.
Not really a bolt in job to use the E4OD. Computer and wiring would do ya in.
Get an AOD donor from a '85 to '93 F-150 with the 302, or '85 to '91 Bronco with a 302. You'll also need the TV cable and throttle body connection.
Adrianspeeder
Adrianspeeder
