94 f150 - clutch linkage snapped, help?
Old Oct 1, 2007 | 12:22 PM
adam romans's Avatar
there is a metal rod (piston i think) that goes into the master cylinder, theres also a plastic fitting on the other end that attaches to the clutch pedal linkage right over the gas pedal... and this is where it snapped off... damn plastic parts!!! am i gonna have to replace the whole damn master cylinder or can i grab another one of these rods (piston, or whatever it is), at a scrap yard and throw it in?
thanks for any help
adam
Old Oct 1, 2007 | 01:59 PM
Steve83's Avatar
There's no plastic linkage. There are plastic bushings in the linkage, and the MC pushrod has some plastic coating. Does the clutch pedal still work normally? Click my black Bronco below & look in the Hydraulic Clutch album, and get a Haynes manual or Ford service disk.
Old Oct 2, 2007 | 02:21 PM
here
check out this link
http://www.napaonline.com/masterpage...aster+Cylinder
the left tip of that rod (plastic) broke off.. i wonder if its as simple as yanking that whole rod out
Old Oct 2, 2007 | 08:14 PM
Steve83's Avatar
Yes, you can pull the rod out of the MC, but that's not a stock MC. Every Ford one I've seen has a plastic coating over a steel eye, or a bare steel eye.
Old Oct 3, 2007 | 09:22 AM
ok
cool thats probly why it decided to break then
im gonna try n yank er out
thanks
Old Oct 3, 2007 | 12:09 PM
Steve83's Avatar
That would be what ALLOWED it to break, but the CAUSE is probably that the linkage isn't properly adjusted. Read this caption:
Old Oct 4, 2007 | 12:08 PM
special tool
it seems i need a special tool to remove the master cylinder line. theres a dust boot i removed and it looks as though i'm supposed to take that angle to remove
the line... im tempted to cut the line itself and just "adapt" the new line onto where i've snipped it.
i've heard of people using a "clutch coupling tool" to remove it, but those kind of tools are hard to come by.
any suggestions?
Old Oct 4, 2007 | 12:09 PM
its a 4.9
any suggestions?
Old Oct 4, 2007 | 05:49 PM
1982_F150's Avatar
Isn't there a roll pin that holds the line in? I remember on a ranger I had that the line was held with a roll pin - once the pin was driven out the line slips out easily.
Old Oct 5, 2007 | 11:37 AM
Steve83's Avatar
It's either a roll pin, or a lock ring. If it's the ring, just push it in & pull the line out, as shown in the bottom R of this diagram:
You don't need the fork tool; a flat screwdriver or needle-nose pliers will work.
