My overdrive broke!
Old Aug 21, 2007 | 06:20 PM
osunajr's Avatar
My overdrive broke!
Hi,
My overdrive on my 2002 F150 4.6L broke on the freeway. I was accelerating to catch up with the speed of the traffic and suddenly I felt loss of power. I looked at my tachometer and the RPMs were really high, that is when I new something broke. I stopped and started accelerating again and as soon as it shifted into overdrive, again the same symptom... no power. So, I had to turn overdrive off to be able to drive.
Anyone has an Idea what could be wrong?
All of the other gears work fine except for overdrive.
Your comments are appreciated ...
Old Aug 21, 2007 | 11:52 PM
OhioLariat's Avatar
Originally Posted by osunajr
Hi,
Sounds like your OD solenoid may not be engaging. Maybe it could just be an electrical connection problem. I'm sure others will chime in with reccomendations.
(OD also won't work when you re-assembled the solenoid incorrectly, and the band can't engage. DAMHIK.)
Andy
Old Aug 22, 2007 | 03:50 PM
osunajr's Avatar
Thanks, I hope it is just the OD solenoid... at least I want to have an idea of what could be wrong before I go to a tranny specialist, I don't want to go there and blindly believe what they tell me and get ripped off ...
Old Aug 22, 2007 | 04:49 PM
phil6608's Avatar
When it shifts to OD dose it feel like it's in neutral?
Phil
Old Aug 22, 2007 | 05:09 PM
SlammaJamma's Avatar
Mine did that, $2200 later I had a re-man transmission in my truck But my reverse went out at the same time so my whole transmission was shot.
Old Aug 22, 2007 | 05:17 PM
osunajr's Avatar
Yes, it feels like it is in neutral.
Old Aug 22, 2007 | 08:01 PM
phil6608's Avatar
Same thing just happened to my truck but I lost OD and 3rd.Had to drive it home in second. First and second were just fine.
Sorry to say but It's toast! Time for a rebuild.
Phil
Old Aug 22, 2007 | 08:15 PM
osunajr's Avatar
I still hope it's just the OD band .... could this be the case ?
Anyway, thanks for your inputs, I'll be taking it to the mechanic over the weekend ...
Old Aug 22, 2007 | 08:37 PM
phil6608's Avatar
Yes it could be just the OD I think. mine was just OD and 3rd.
But,, by the time they take it out of the truck/take it all apart/fix it/put it back together/put it back in the truck.
Don't be surprised if it's at least 1500. maybe more.
Good luck with it,,,,hope you get it all fixed up.
Phil
Old Aug 22, 2007 | 11:29 PM
jethat's Avatar
If it needs to be removed
you really should rebuild the whole thing. might cost a few hundred more but better safe than sorry. It sounds to me like it is job that would require removal..
