Looking for info
Old Jul 25, 2007 | 12:47 PM
taylordr's Avatar
Looking for info
I see some sort of pump or compressor looking thing above the rear axle under the bed of my truck. Does anyone know what it is? Also how do I find out what rear gear set I have from the factory? Are they all 8.8" housings in the 2004 ford 150 fx4 supercrew?:
Old Jul 25, 2007 | 07:16 PM
OhioLariat's Avatar
You may have the load-leveling suspension option, which would explain the compressor, and there will be a tag on the differential to indicate what gear set is installed. There may be a tag on the driver's door, as well. Someone else will chime in, I'm sure.
Andy
Old Jul 25, 2007 | 07:47 PM
kingfish51's Avatar
If you have an 04 FX4, it has a 5.4 engine. With that you get a 9.75 rear diff. As far as a compressor, to my knowledge, there was no option for air bags or a load leveling suspension. Pictures might help.
Old Jul 25, 2007 | 09:13 PM
adrianspeeder's Avatar
Post the axle code from the door jam sticker.
Get a pic posted if you can. I've heard about (never seen) a load leveling suspension option on '97's but not for '04.
Adrianspeeder
Old Aug 1, 2007 | 10:53 AM
taylordr's Avatar
I'll get a pic soon. Where's the fuel pump on this particular truck? In the tank or on the frame?
Old Aug 1, 2007 | 11:52 AM
kwb377's Avatar
My Expy has the charcoal/evap cannister in the same place you describe...could be that.
Old Aug 3, 2007 | 09:06 PM
In tank. The last year for gasser frame pumps was '89.
Adrianspeeder
