4 wheel low
Old Jul 23, 2007 | 11:46 PM
vuk75's Avatar
4 wheel low
I went and did some off roading this weekend and noticed 4 low is not engaging 4 high works fine but no 4 low anybody had this issue?
Old Jul 24, 2007 | 01:07 AM
twintips_17's Avatar
What year truck. Does it have the electric 4x4 or manuel?
Old Jul 24, 2007 | 09:58 AM
vuk75's Avatar
Its a 99 with electric just statred doing this
Old Jul 24, 2007 | 12:30 PM
not the man to talk to about the electric style. Sorry. I would start checking. Maybe you broke a sensor off roading.
Old Jul 24, 2007 | 12:43 PM
UCF-150's Avatar
you put it in neutral before going to 4wd low right?
Old Jul 24, 2007 | 02:16 PM
Thats a good point. YOur not trying to go to 4low while still in drive. IT wont work. IT will only go to 4high while in drive. You ahve to put it in nuetral to go to low.
Old Jul 24, 2007 | 08:50 PM
Dont you guys just love 4 posts from the same guy about the same thing??? SUPER
Old Jul 24, 2007 | 09:41 PM
vuk75's Avatar
sorry to offend u my server was having a bad evening!!!!!!!!!!!!! yes it was in neutral I didnt see anything out of the ordinary as far as sensors go but I will check again thanks for the tips tips tips tips..... ha ha
Old Jul 25, 2007 | 02:58 PM
GIJoeCam's Avatar
Stopped, In neutral, foot on the brakes. Most people forget the third part.
If that's the procedure you're following, you need to start chasing electrical gremlins... not fun.
-Joe
Old Jul 25, 2007 | 08:39 PM
spanky55618's Avatar
try by checking your fuse to the 4low... that was my problem...
Old Jul 25, 2007 | 09:10 PM
adrianspeeder's Avatar
GIJoe has it right by sayin the computer won't shift into or out of low range unless the truck is stopped, neutral, foot on brake, and a working third brake light.
Check that out and try again.
Adrianspeeder
Old Jul 26, 2007 | 01:02 AM
vuk75's Avatar
Im thinking its electrical Ill keep ya informed. I appreciate all the input !
Old Aug 7, 2007 | 02:57 PM
wirebender777's Avatar
Mine just started doing the same thing. (And I have used 4L many times in the past). Please update with your diagnosis.
Old Aug 9, 2007 | 08:50 PM
LSVFD's Avatar
those trucks are bad for water entering the GEM module , could be causing this , the GEM receives a signal from your switch and commands the encoder motor to shift into 4 low , are you haveing any other problems with your truck? intermittant items inopt? if so then its gotta be a GEM
