Diff Gear Changes 06 FX4
I bought my 06 FX4 as a left over a couple months ago. One of the things it had was a 3.55:1 rear end which I wasn't too happy about, but since I was told it was fairly easy (and cheap) to swap it out, I figured no big deal. So, I was going to upgrade to the 3.73:1 rear end, but now reading on the forums a bit, I see people who lifted ended up with the 4.88:1 and it appears even the 4.10:1 is a valid ratio. (Keep in mind, I'm new to this stuff, so my questions may be a little noobish)
So, assuming I plan to lift my truck (eventually; using a rize 6" kit most likely), would it be safe to go with the 4.88:1 now, assuming that's months away, or would I be better choosing the 3.73 or 4.10? And do I need to swap both a front and rear diff? How do the 5.4L modulars handle gear changes? I would assume I could use any of the 8.8" diff gears offered by Ford Racing (for front and rear)?
Originally Posted by Super FX4
what problem will happen if you put it in 4x4 with a different gear ratio in each end?
In this case, given enough available traction, it'll be either the diffs, axles, joints, x-fer case, etc.
Both ends must be geared identically. Period.
