Shutter when downshifting from OD
Old Sep 26, 2011 | 08:42 AM
projectSHO89's Avatar
Low-grade misfires most often occur when in overdrive while at lower RPMs under higher load. For example, go up hill in OD and let the engine lug down without downshifting. This condition places the greatest load on the secondary ignition system and most often induces the low-grade misfire.
If the shudder occurs AFTER the downshift, then it's far more probable that you are experiencing torque converter shudder. Follow Mark's advice from several years ago (above) with a fresh fluid exchange.
Old Sep 26, 2011 | 11:32 PM
jquez's Avatar
Quote:
Originally Posted by gregerm
on my 04 screw 4x4 5.4 Automatic trans, I will be driving down the highway around 70 mph. when I slowly step on the gas just enough for it to downshift out of overdrive every now and then I feal a huge shutter or vibration. It feals like ran over those stripes on the side of the highway that make a big vibration and noise. It almost feels like when you upshift in a standard trans into a gear thats to high and the engine cant keep up. But it only happens when the trans shifts from od. I cant figure it out.
Old Sep 27, 2011 | 08:15 PM
PickledPolak's Avatar
TCC shudder!! Very common.
Old Sep 30, 2011 | 10:51 PM
White06SCrew's Avatar
Guys, I just went through all of this with my 06. The good news-it is now solved. The bad news-its your torque converter.
These trannys do have hydraulic issues, which can screw up the clutches in the TC. Find a shop that can diagnose tranny issues with a scanner.
Old Oct 2, 2011 | 01:37 PM
Summit800's Avatar
Hey Guys, i was just experiencing this same shutter as well, for about a couple weeks, but then yesturday it went to downshift and it missed third. It completely blew 3rd and 4th gear and left me with only 1st and 2nd. As soon as it tried to go into 3rd, it just rev up to 5000 rpm.
Old Oct 2, 2011 | 06:38 PM
Tell the service writer at your transmission shop. He's the one that's going to write the work order for your rebuild.
Old Oct 11, 2011 | 03:58 PM
edwardsjr1's Avatar
I had the same "shudering problem". I thought it was the tranny from towing my heavy toy hauler. I serviced the trans, still shuddering. Next I figured it was misfire, changed the plugs, viola-fixed the problem. Probably the cheapest place to start. If you plugs are bad but coils are good, you won't get an engine code.
