Clutch problem
Old Feb 7, 2007 | 11:17 AM
'03beast's Avatar
Originally Posted by JMC
'03beast,
Thanks for the compliment. The truck started life as a 4.6 with 5 speed manual. I swapped in the 5.4. Mike Troyer does my tuning. He reprogrammed my chip for the extra displacement. BTW I am on tranny #4. The next tranny will be a ZF from a SuperDuty.
JMC
Ah gotcha. haha damn 4 transmissions thats crazy but the 5.4 makes a lot of low end torque so i wouldnt expect that m5od to last long behind it. Putting in a zf would be really sweet. Will they bolt up using the same bellhousing or do you need to get one from a super duty?
Old Feb 7, 2007 | 12:05 PM
JMC's Avatar
JMC
25 Year Member
Both transmissions have the Bell housing as an integral part of the tranny. I will need a Clutch and flywheel and T-case from a SuperDuty. Because the tranny t-case combo is longer then the M5OD I will need to have the front drive shaft lengthened and the rear shortened. I will also have to adjust th shift linkage to fit the F-150.
JMC
Old Feb 7, 2007 | 12:36 PM
'03beast's Avatar
JMC
Sounds like it should be a pretty bad *** setup when all is said and done.
Old Feb 7, 2007 | 12:40 PM
JMC's Avatar
JMC
25 Year Member
A friend of mine has an 06 with the 6L and he is putting over 1100 ft/lbs of torque to the rear wheels. If his doesn't break I certainly will not brake one.
JMC
Old Feb 7, 2007 | 05:10 PM
'03beast's Avatar
JMC
Haha yea seriously i should hope not. whats ur 5.4 putting out?
Old Feb 7, 2007 | 06:23 PM
JMC's Avatar
JMC
25 Year Member
I can't remember but I think it is some where around 250hp and 325ft/lbs to the wheels.
JMC
Old Feb 7, 2007 | 10:51 PM
'03beast's Avatar
wow nice thats awesome especially to be matted infront of a 5 speed
