tranny cooler question HELP PLEASE!!!!!
I have '04 f150 5.4l (with a few mods) was wandering if there was any way to replace factory tranny cooler from tow package with a larger cooler.
here's the prob though, the lines don't seem to have any type of Quick connect or screw fittings. ANY HELP WOULD BE APPRECIATED!!!!!!!!!!!!!!!!!!!!! |
Why do you feel you need a larger cooler?? From what I've seen, those coolers are pretty big and more then capable of handling anything your F150 was designed to do?
Do you have a trans temp gauge? Or are you reading the trans temp from a tuner? Do you know what trans temps you are getting? No idea on your dilemma, just asking some other questions to understand the problem...;) Mitch |
Howdy, your smart for worryin about your temps. I'd first just add a gauge though to see what you are runnin at currently. About 50bucks at any parts store.
Adrianspeeder |
trans temp
according to ford data logging, trans stays around 195-202. It's not that I neccessarily need a bigger cooler, but would like one for peace of mind.
Also I' having trouble finding a way to install a trans temp gauge in my 4R75W trans, any help would be apprecciated!! |
Everything I've seen says one should supplement the factory cooler, not replace it.
I'm going to be using my '99 for towing, and have a new cooler sitting in the garge awaiting installation. Here's my thread about it: https://www.f150online.com/forums/sh...d.php?t=255731 HTH Andy |
Help!!!!!!!!!!!!!!!!!!!!
seriously can anyone give me advise on installing trans temp gauge in my trans, while keeping stock computer sensor, or is it possible to tap into stock sensor some how!
Also I' having trouble finding a way to install a trans temp gauge in my 4R75W trans, any help would be apprecciated!! An auxiliary cooler mounted in teh return line between the radiator and trans is never a bad thing. The cooler the trans fluid is, the longer the trans will last. -Joe |
The way I prefer to mount the temp sensor is in the cooler line. The side you choose is up to you. On mine I am running 2 sensors (1 in each line) and a gauge with a switch so I can select which one to read. Making the junction is a bit tricky. I buy a 1/2 pipe tee in brass and then get the fittings to go in it to connect to the line. (I like to use 3/8 inverted flare and bend 3/8 lines but you may want to just bubble flare existing lines and use hose barbs) You will have to ground that junction for the sensor to work. To do that braze a bolt onto the tee so you can tighten a ground strap to it.
Alan |
I moved my factory cooler from the lower frame to in the grill opening about 6 inches in front of the radiator and it lowered my temps signifigantly. Then again, mine is a 6000+ pound SUV designed to tow whatever you want whenever you want. (until I got a hold of it anyway. I just extended the rubber lines with fuel line
Add one to it. |
gauge
okay, I still would like to add a trans gauge but with out modifying stock lines. Is this even possible?
