AOD linkage problem
Old Oct 5, 2006 | 04:32 PM
solemeans's Avatar
AOD linkage problem
I've put a 302 roller w/aod from 85 mercury grand marquis in a 70 f100 swb. Trying to keep the column shift. Need suggestion on shift linkage.
Old Oct 8, 2006 | 01:01 AM
trevorus's Avatar
If the truck had an AOD before, you could use its linkage in the new trans. Otherwise, they can be flipped over to allow for use of a different linkage. You have to drop the pan, loosen the nut on the shaft, and turn it 180*. When I replaced my AOD, I had to use my old linkage lever. Also, be SURE to set the TV cable adjustment with a pressure gauge.
