OD light blinks .. help.....
Old Sep 21, 2006 | 09:36 PM
miloford's Avatar
2000 v6 light when you get in, in the morning and start it, it blinks for a few minutes and then stops. then the light does not come back on when you go to turn the car back on (you know how all the lights, light up) well the od light does not come on. it does shift fine and the od button turns the overdrive on and off with no problems to.. any ideas??????? help
Old Sep 21, 2006 | 10:01 PM
casey_1's Avatar
When the light flashes a code is stored in memory. It will stay there even if the light doesn't flash again. Get it read, and then you'll have a BIG clue as to what's wrong.
Old Sep 21, 2006 | 11:40 PM
miloford's Avatar
well i just hope it is not big money
Old Sep 22, 2006 | 08:41 AM
projectSHO89's Avatar
If it's transmission related, what are the odds that it won't be expensive?
Steve
Old Sep 22, 2006 | 09:00 AM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Just count the blinks.
When it pauses , that's where the decimal point goes.
