Very Weak Clutch
Old Sep 7, 2006 | 08:26 PM
Fett 88's Avatar
Very Weak Clutch
Ok lately I my clutch's tension has gotten less and less and right now I have to go about 4 inches from the floor the put the clutch into gear. People have told me that the flywheel is worn down but they dont know for sure. Any help would be helpful. thx
Old Sep 9, 2006 | 12:36 PM
JMC's Avatar
JMC
25 Year Member
As the clutch disk/flywheel wear out the friction point gets closer to the top of the pedal. If you are having to press farther down disengage the clutch then you have a leak somewhere in the lines, hydraulic, or the cable need to be adjusted.
JMC
