05 XLT trans
Hi everyone, how ya doin? Quick question, I have an 05 F150 XLT with the 5.4 and every now and then the trans will shift 1st to 2nd real hard right around 15-20 sometimes i get a humming noise to, only from 1st to 2nd though. Ive already got 32,000 on her and thats my only complaint besides the vibration from 60-70 that everyone seems to have. So anyways has anyone else had this problem? Would a shift kit help or mabey the edge? any help would be appreciated.
Nedf
At full throttle I get a shutter when shifting from 1st to 2nd. 05 screw xlt.
Mine did the same thing until I had it reflashed at the dealership.
Originally Posted by NEDF
I HAVE THE SAME VEHICLE AND I AM GETTING THE SAME NOISE. WHEN YOU START OFF AND GET AROUND 20MPH WHEN IT SHIOFTS FROM 1ST TO 2ND GEAR IT SOMETIMES MAKES A LOUD KNOCKING NOISE. I HAVE HAD IT ALSO MAKE A GRINDING NOISE FROM 1ST TO 2ND. NEITHER ONE OF THESE PROBLEMS DOES IT ALL THE TIME. I HAVE TAKEN IT TO THE DEALER AND THEY COULD NOT GET IT TO DO IT. THEY SAID THEY CAN'T REPAIR IT UNLESS THEY HEAR THE PROBLEM.
Ford has a TSB on this problem. It is a software problem and is easily corrected. You can look up your vehicle TSB here:http://www-odi.nhtsa.dot.gov/cars/problems/tsb/ You can then tell the dealer the TSB number of your problem and they don't have to "hear" it to correct it. This is what I did to correct the problem. I hope this helps |
excellent info thank u very much timtirble. Im gonna take that TSB# to the dealer and stick it to them.
https://www.f150online.com/galleries...957-168799.jpg |
So the dealer falshed my computer and WOW! I've got firmer shifts all around and it feels like there might be a little bit more get up. Thanks again for everyones info, P.S. the dealer said the TSB did not include my truck(05 XLT) but i had them flash it anyway. Thanks again.:thumbsup:
Mine was an 05 XLT as well but they did the reflash with the newest codes.
