Help!!
Old Aug 3, 2006 | 10:52 PM
HENSON's Avatar
Help!!
My OD will not turn off, can sum1 help please?
Old Aug 4, 2006 | 08:54 AM
projectSHO89's Avatar
Check the wiring in the shifter arm and steering column. Common failure point if the switch is good and the supply fuse is not blown.
Steve
Old Aug 4, 2006 | 09:41 AM
adrianspeeder's Avatar
"sum1" hahahah
Anyway, pull off the cover under the steering column and check the small wires that come out of the shifter tube to make sure they are not broken. Splice if needed.
And like steve said, check your fuses.
Adrianspeeder
Old Aug 4, 2006 | 03:16 PM
dptyscott's Avatar
my 94 has a plug down there that has to be plugged in too.
