NO pressure on clutch
Old Aug 3, 2006 | 09:20 PM
justin_76's Avatar
Question NO pressure on clutch
I had to replace the ring gear on my 89 150 5 speed and when i got it all back together the clutch goes straight to the floor and stays. Could this be air in the lines and all i need to do is bleed the system? If so its the same procedure as brakes right? Thanks for any help. This place is worth a million bucks to the do-it-yourselfer.
Old Aug 4, 2006 | 01:59 PM
dptyscott's Avatar
I would say thats a good place to start. if the clutch works off a slave unit start bleeding at the master cyl. its self and work your way down. good luck
