should I change front seal
Old Aug 3, 2006 | 08:53 AM
dptyscott's Avatar
while the eng. is out should I change the front trans seal. I have noticed some wetness but not going low enough to need to add any.
Old Aug 3, 2006 | 09:19 AM
projectSHO89's Avatar
You want to pull the tranny in a few months to replace it?
Look for a VITON-enhanced aftermarket seal. Far better than OEM grade. Contact your local transmission supply house.
Steve
Old Aug 3, 2006 | 11:21 AM
dirtyd0g's Avatar
Steve
I don't like the way the aftermarket ones install into the pump housing they fit too tight and one little knick can cause a leak on the outside of the seal. I stick to the oem seals they have never given me a problem. Everytime I have had a front seal leak on a transmission less than 20 years old it was because of a bushing problem.
Alan
Old Aug 3, 2006 | 02:22 PM
dptyscott's Avatar
thanks for the replies. I am definatly going to do the seal and service the trans( drain converter/filter/ fluin pan gasket) before putting the engine in.
Old Aug 11, 2006 | 02:55 PM
dptyscott's Avatar
Red face
well i did the deed and used a oem seal from napa. Hope I made the right choice. I put in my new rebuilt 351 and all is well after working out a few bugs. the only problem if it is at all is there is a slight hesitation or slip when getting on or off throttle so I am not sure if its drive train or the motor. what yall think?
