3 on the tree...trouble shifting
Linkage seems to be set where it works best when it does shift...the problem is when coming back down from 2nd or 3rd its hard to get it to drop back down into the 1st/reverse gears....you have to really jam it for it to go....I think there is a issue in the column?
Could be
Is this while moving? I double clutch the 71 and 66's to get into first easier.
If while stopped to, the R/1 shift linkage could be bound up. Make sure all the joints are greased.
Adrianspeeder
Adrianspeeder
