Leaking Rear Differential
Old Jul 4, 2006 | 09:42 AM
treetyFX4's Avatar
Question Leaking Rear Differential
Need some advise. The rear differntial on my 2005 F150 FX4 (20,000 mls) looks like it's pushing out grease (it's not dripping though). I have no idea for how long that's been going on. Is that a common problem and do I have to be concerned about it?
Old Jul 4, 2006 | 11:38 AM
adrianspeeder's Avatar
Howdy and welcome!
Where is your leak? The pinion seal (where the driveshaft comes in from), or around the rear cover seal?
Which engine do you have?
Adrianspeeder
Old Jul 4, 2006 | 12:45 PM
treetyFX4's Avatar
Thanks for the welcome - this web site is great!
It's a 5.4l engine. The leak appears to to be around the rear cover seal.
Old Jul 4, 2006 | 01:04 PM
fords8's Avatar
Change the gasket on the rear cover.
Old Jul 4, 2006 | 01:37 PM
JForestZ34's Avatar
Does it even have a rear gasket. I've read other post that the rears don't have a gasket. Or is that with certain rears.
James
Old Jul 4, 2006 | 01:44 PM
fords8's Avatar
Some do, some don't. I think that one does tho. If it doesn't, you use RTV on it instead.
Old Jul 4, 2006 | 03:29 PM
doctorD's Avatar
Change your diff. lube while you are at it. I try to inspect my undercarriage every couple thousand miles just to watch for leaks. I've got 17K miles on my 4x4 Screw lariat.
Old Jul 4, 2006 | 05:47 PM
Zaairman's Avatar
It sounds like it's just the RTV sealant coming out...as long as it's not leaking, I wouldn't mess with it until its time to change it.
Old Jul 4, 2006 | 06:01 PM
fords8's Avatar
Rear dif fluid is thick. Maybe you think it looks like grease, but it really is the fluid.
I would think he would of reached under the rig and touched it. Maybe he could take a pic of it for us.
Old Jul 4, 2006 | 06:37 PM
Zaairman's Avatar
A picture would help...
Old Jul 5, 2006 | 12:18 PM
chester8420's Avatar
I agree.
Old Jul 5, 2006 | 12:38 PM
SM's Avatar
SM
If it actually is leaking, with an '05 with only 20k miles, why not run it in to the dealer and let them deal with it? Should be well within warranty.
Old Jul 10, 2006 | 10:53 AM
mmotes's Avatar
I aggree...take it to the dealer...save yourself some time and money...diff cover swap or diff cover gasket install can be messy...good luck..._motes
Old Jul 10, 2006 | 01:52 PM
Good excuse to swap in a bling cover though...
