Major 5-speed Problem. Help!!!
Old May 6, 2006 | 12:00 PM
f-150sport03's Avatar
I've recently had a lot of problems with mis-shift. Ie: I can't get into a specific gear sometimes. It's things like when I have to take around a minute to get it into reverse. That was prob'ly the worst. And, my occasional 3 to 4 mis-shift. It won't let me into 4 or 5, so I have to slow down, shift to 2nd, then proceed through the gears. It only happens around 1-2 times per month, but that's often enough to have me worried. Any ideas? Is my truck PMS'ing? (Just kidding, please don't take offense to that)
Old May 6, 2006 | 12:46 PM
adrianspeeder's Avatar
Milage?
Take the 15 minutes and get some fresh Mercon ATF in there to notice any difference.
Adrianspeeder
Old May 6, 2006 | 01:34 PM
milage: 56k.
As for the Mercon ATF, OK. I'll do that ASAP.
Thanks, man.
Old May 7, 2006 | 03:04 PM
Originally Posted by f-150sport03
milage: 56k.
Thanks, man.
Cool, it is pretty easy to do and you are due for a change of fluid.
I think it was 4 quarts, but just fill till you can't put anymore in. A hand pump or suction gun makes the job go real fast. Don't lose the washers on each plug.
Adrianspeeder
Old May 7, 2006 | 04:26 PM
wittom's Avatar
Just curious. How do you drive the truck?
My '98 had about the same mileage when it started getting pretty hard to shift. I drove that truck fairily hard. Mostly fast. I tend to believe that the syncronizers are the cause. I traded the '98 when it had 60k on it so I don't know if it got a lot worse or what.
Changing the fluid did help a bit for me. In the short run anyhow.
I hope you find a solution. I ended up getting an automatic and even with the fickle shifting in the '98, I really miss driving a stick. The F150 I've got now would go real nice with a six-speed. If I only had the money!
Good luck!
Old May 8, 2006 | 05:23 PM
MAJ. Woody's Avatar
Ford truck trannys are not the smoothest shifting beasts around, anyhow. I would definatley change the fluid and also make sure your clutch slave cylinder isn't drifting (internal leak or air)
Old May 8, 2006 | 09:33 PM
OK, thanks. I don't drive the truck hard, but the previous owner most likely did (The clutch seems almost as if it's going out, and there's plenty of damage to the truck body...prob'ly someone's personal vehicle turned personal work truck, in the wrong type of truck.)
Is there a place where I can get the Mercon ATF Changed for me, 'cause I don't have the tools to do it myself (Grease gun or something...)
Old May 9, 2006 | 01:59 AM
JMC's Avatar
JMC
25 Year Member
Press the clutxh to the floor and rev the engine to 2000 rpm. Try shifting into 1st and Reverse. Go from 1st to reverse and back again 4-5 times. If it grinds it is most likely clutch disengagement problems. Try bleeding the slave cylinder.
JMC
Old May 9, 2006 | 08:13 PM
mikey9's Avatar
Would a lube place even put atf in a manual?
Old May 9, 2006 | 09:30 PM
Whapt's Avatar
check out v6f150.com they have a how to to show you how to change it by adding it through the shifter hole up top by removing the shifter instead of using a suction gun
Old May 10, 2006 | 12:58 AM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
Use some mobile1 syn. atf its so simple to do. Take off drain plug and fill plug. let it empty. Buy a cheap hand pump at autozone and some mobil1 atf and simply pump 3.75 quarts back in or until it begins to come out the fill plug.. 10 minutes of your time well spent..
I have over 170,000 miles on my 5 speed and all OEM even the clutch and i have no problems shifting ever....
Old May 16, 2006 | 12:00 PM
Clifford f150's Avatar
It's very easy. A suction gun would make it a bit cleaner, but if you don't have one you don't need it.
Tools required:
-a crescent wrench
-a funnel with a piece of long rubber tubing on it.
-something to catch the old fluid
-rags to wipe things up with
-(not 100% needed but recommended- a buddy to pour new fluid while you hold the hose into the transmission)
Just position a drain pan or whatever you're using to catch the fluid, open both of the plugs, when it stops flowing put in the bottom plug back in, put the rubber tube into the filler hole and route it up through the engine compartment. Attach the funnel and fill'er up! Then put the top plug in and you're done.
You probably don't even have to jack it up unless you're fat like me
Old May 16, 2006 | 02:46 PM
JMC's Avatar
JMC
25 Year Member
Always remove the fill plug first. For the simple reason that if it is stripped and you cannot get it off you will not be able to easly fill the tranny back up. I have had this happen once on my son's car. Luckly we were able to fix it and then proceed to draining the tranny.
JMC
Old Jun 6, 2006 | 12:42 AM
Russ G's Avatar
I swiched to synthetic ATF at 30k and it improved shifting. M50d's are a little nochy to begin with but synth. deffinitly helps.
