Transmission fluid
Originally Posted by mkinttrim
Standards use mercon too! My 91 called for mercon, but after having it rebuilt, the tranny shop said to just run a good synthetic 30 weight in it.
yeah i guess your right
we use mercon in the lenco
...zap!
Originally Posted by zapster
you mention its a standard
you need gear oil not tranny fluid
...zap!
...zap!
Originally Posted by max mitchell
Classic advice from yesteryear!
ahhh maxxxxxxxxxx
i was wondering when the clown show was going to start
look max i'm sorry that we're all not as smart as you
when the term "standard" tranny comes up i naturally assume gear oil
not tranny fluid.. i grew up in the '60's and '70's..and gear oil went in standards...ever try to shift a toploader with tranny fluid in it?
neither did i...
ahhhhhhh but what do i know compared to you?
but i do know this...
you can continue to analize everything i type and thats your option
we never stop learning do we?
i never put anyone on "ignore" but i'm about to
have a nice day...zap!
ahhh maxxxxxxxxxx
...zap!
...zap!
ahhh maxxxxxxxxxx
Ever try to pump 90W when it's 10 degrees outside. 5 hours later it is to the trans.
BTW don't let maxie pad get to you, he never said what he would use. He probably never checks his. Likely doesn't know what a trans is, where to find it, much less where to check it. His post was just a useless non-informative waste of bandwidth.
He's googleing now to try and find something so he can try to look smart.
There is no need to deteriote this thread into a spat.
Look in the upper right of the posters inital post.
It says 2001 v6/4.2.
The spec fluid is Mercon for that truck.
If anyone wants so use gear oil, thats fine but don't complain how the trans shifts and especially in cold temps.
Wasn't that the stuff they found in cans of Tuna years ago?
