I Removed the Shifter in reverse
Old Mar 5, 2006 | 10:21 AM
b_treaster's Avatar
I have a 1989 Ford F-150 with a 5-speed M5OD manual transmission. I took the shifter out the fix the boot and put a new noise dampener in. Well, I took the shifter out while the transmission was in reverse. How do I shift it to neutral or put the shifter back in? Thanks Phsdixieboy@yahoo.com
Old Mar 7, 2006 | 10:22 AM
JMC's Avatar
JMC
25 Year Member
Use a prybar to shift it back into neutral. Push the left most shift rail backwards till the notches line up with the other two.
JMC
