drain on torque converter
Draining only the pan gets less than half of the fluid. That's not worth the effort. I use this method:
http://www.ford-trucks.com/article/i...nsmission.html
Originally Posted by John Patterson
Any reason why the torque convertor cannot be drilled and tapped to use an 1/8 pipe plug? Sure makes it so much easier to drain at home.
Adrianspeeder
I just wonder how much the balance would be off, if it would be enough to cause any vibration problems. Dan, I figured that after drilling the hole, the fluid would wash out the cuttings, and then I would try swabbing around the hole to try and clean out any more cuttings. Oh, well,
