Transfer Case and rear end differential - Fluid Change
My Chilton's manual recommends draining the rear end fluid from the filler whole first, then taking off the cover and cleaning out the grime inside. Put the cover back on, then fill through the hole. Make sure you add the appropriate friction modifier for posi.
