Trans codes
Old Jun 26, 2005 | 01:38 PM
Grocer for life's Avatar
Trans codes
Hi there...I have 02 150 , 7700 with E4Od transmission..My question is ...what is the difference between a E4Od and a 4R70W transmission..I have tried to read some of the forums and stuff on the web but nothing seems to satisfy my curiosity...Thanks for your help everyone!! Grocer for life !!
Old Jun 26, 2005 | 02:42 PM
dirtyd0g's Avatar
They are completely different tranny. The 4r70w is the light duty version and has 14 pan bolts also it roots from fmx transmissions. The e40d is massive, has 20 pan bolts and roots from c6 transmissions.
Alan
Old Jun 27, 2005 | 09:10 PM
Hi again and thanks...I also have another couple questions...Is this transmission normally used in f250's and also , the transmission cooler that comes stock with the truck ( with the trailer tow pkg) usually good enough for towing...I have a 25' travel trailer to tow , approx 6700 lbs...Thanks again..Grocer for life
Old Jun 27, 2005 | 10:29 PM
dirtyd0g's Avatar
AFAIK 250's are only available with the larger trans the 4r70w is the 150 series trans. Like anything their are probably exceptions to the rule but I have never seen one.
Alan
Old Jun 27, 2005 | 10:38 PM
Quintin's Avatar
I've got a '97 F250 LD (before they called them 7700s) with the E4OD too...Alan's on the money, 150s have the 4R70W, E4ODs are pretty much mostly seen in 250/7700s, Superduties, Navigators and some Expeditions.
Old Jun 29, 2005 | 09:43 PM
Thanks everyone for the info...Grocer for life
Old Jun 30, 2005 | 03:21 AM
MitchF150's Avatar
I've got a '97 F150 with the e4od (trans code E). GVWR is only #6250. I tow a #4500 travel trailer with the stock cooler and it'll run 180* in the summer.
Mitch
