M5OD to ZF tranny
Old Jun 15, 2005 | 11:21 PM
CEE21's Avatar
M5OD to ZF tranny
Can you put a ZF tranny into a 97 4.6 4x4 with a M5OD and what sort of adjustments would have to be made?
Old Jun 16, 2005 | 07:35 AM
adrianspeeder's Avatar
That would be a lot harder than on a 96. All of the suspension stuff is in the way and is tricky to adjust, as I do not think the trannys are the same length. It is hard enough just to do a clutch job on these 97+ Why no likey the M5OD?
Adrianspeeder
Old Jun 16, 2005 | 04:10 PM
CEE21's Avatar
I was just wondering. Do you know if there is an upgrade to these pos slave cylinders or if you could use a ZF tranny hydraulic clutch system.
Old Jun 21, 2005 | 09:04 AM
JMC's Avatar
JMC
25 Year Member
The ZF uses the same "POS" system.
JMC
Old Jun 21, 2005 | 10:11 AM
Hmm, I have always had good luck with the slave cylinders. What is wrong with yours?
Adrianspeeder
Old Jun 21, 2005 | 10:31 AM
JMC's Avatar
JMC
25 Year Member
The newer versions have dust covers or boots that keep the dust out of the works. My current slave cylinder has this and it has lasted for over a year now without leaks.
JMC
