Gaer Swap
Old Jun 1, 2005 | 05:57 AM
zapster's Avatar
to everyone...i have said over and over to bring this to general discussion...sorry for wasting this"post" but when someone says your "inept crass and illeterate" one must stand up for him/herself...by the way i still get no answers..max must be a lawyer or something answering questions with questions...and still no answers.. i was actually hoping a moderator would bring this to general...zap!
Old Jun 1, 2005 | 10:01 AM
Wife'sF150's Avatar
What i was told was that because of the overdrive in the 04 F150's that the 4:56's aren't really what you need in it. The guy who is putting them in talked to the US Gear guys in Chicago and they recommened that I go with 4:88's because of the tire size(35 x12.50) and overdrive. It all has to do with the overdrive set up. I questioned him because of the rpm issue. He said that I will run around 2100 rpms at 60 mph. I will be quicker off the lights and it will tow better. I Tow an Off Road Jeep, boat or camper at times. It is to late now to go back,because it is on the rack as I type. I'll let you know. I was getting only 12 mpg with the stock gears and the bigger tires and 6" lift. I used 1/2 a tank to go around 120 miles over the weekend so it can't get worst I hope.
PS It appears Zapster has crawled back under his rock. As my late Dad use to say "You are what your words say"
Old Jun 1, 2005 | 02:17 PM
Brian 5.4's Avatar
Yeah, you don't buy one of these trucks to get good fuel economy anyway. In the end, it doesn't really make a whole lot of difference what kind of mileage you get, because we all knew going into it the trucks would suck gas. I would be interested to know the results when you have the truck back, though.
Brian
Old Jun 1, 2005 | 03:24 PM
Jordan not Mike's Avatar
I agree - you won't see a significant MPG difference, but the shorter gears will make your truck feel a bit more responsive.
I've got 4.10s on street tires (31.5-inch equivalent diameter), and my MPG didn't really change all that much (had 3.31 gears before) but driveability is WAY better with the shorter gears.
Old Jun 1, 2005 | 03:44 PM
zapster's Avatar
...zap!
Old Jun 1, 2005 | 06:31 PM
RockyJSquirrel's Avatar
Let it go, Zap. My father used to tell me "When you find yourself in a hole, the very first thing you do is STOP DIGGING!".
Old Jun 1, 2005 | 06:41 PM
zapster's Avatar
yeah i'm getting nowhere your right rocky...i can't believe that i stooped to this level...to all that have a clue ...later...zap!
Old Jun 5, 2005 | 01:56 AM
Pyromite78's Avatar
Originally Posted by max mitchell
racerf150man-
I'm not required to answer questions. At most, you saw "didn't choose to answer", not "can't". Also, my personal information is of no concern to the insignificant.
zapster- Ranting is common in the emotionally impaired.
Others- This is a quote zapster makes corroborating my analysis:
One member writes:
zapster responds:
Here is the full post of origin: https://www.f150online.com/forums/sh...ghlight=hockey
WWWWWWWWWWWWWWWWWWWWWWWWHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOOO CARES???!!!???!!
As for the gear thing... So you all say MPG are that noticeable on a gear upgrade? Hmmm been thinking about doing this one... how much would it run to do 4.88's on a 2wd?
