U-Joint inspection
Old Apr 25, 2005 | 01:44 PM
keyfish's Avatar
U-Joint inspection
I'm trying to identify a rattling noise coming from my trans or somewhere in the drive line of my 97 F150 4.2, automatic
(posted as "Drivetrain noise"). I checked the U-joints as suggested by dirtydOg and the rear set is tight, but the front has a lot of play. I can move the shaft approx. 1/4 inch in all directions, but can't tell if it's the joints. What I can see, is movement where the slip yoke enters the case. How much lateral movement should exist if any? Also, what rear end do I have with an 18 axle code?
Old Apr 25, 2005 | 05:42 PM
chucks bp's Avatar
Code 18 is a 3.08 non limeted slip. There should be no movement at the slip yoke to the case, normaly if the u joit has failed there will be a fair amount of red rusty residu around the u join cups, sounds as though you will need a tailshaft bushing and seal, you can better tell the u joints integrity with the drive shaft removed.
Old Apr 25, 2005 | 05:53 PM
keyfish's Avatar
Thanks chucks bp, I'll have the bushing and seal replaced as well as the joints. Would you happen to know what the towing capacity is for this truck?
