'97 4R70 Questions
Old Feb 3, 2005 | 10:00 AM
jed_1068's Avatar
'97 4R70 Questions
Does anyone here have access to parts numbers I would need in order to change out/update the 1-2 & 3-4 accumulator piston/springs?
Also, while I'm under there I thought I'd see about replacing the speedo gear to correct the reading since I'm running a little larger tire than stock - how might one calculate or figure out how to do that?
Thanks,
Jamie D.
Old Feb 3, 2005 | 12:56 PM
dirtyd0g's Avatar
How hard do you want it to shift? If you want it to shift better than stock buy the stock ones for a 2001 5.4.(except the inner lower) If you want it really hard just buy the upper one (brown) and don't use a lower. All of the 2-3 springs are the same.
Alan
