buying 97 f-150 clutch question
http://autotrader.com/fyc/vdp.jsp?ca...p=y&cardist=24
That is the truck i am getting. He is most likely delivering it this week. It has the updated 4.2 without all the engine problems. It has 4k miles on the engine and 130 on the body and frame. For 4 grand would you say that is a good deal?
My question is when i let it out in first at lower rpm it seemed to chatter a bit. I did not notice it when i let the clutch out with a little more throttle applied. My dad seems to think the clutch plates might be warped or something. Is that a possibility? Or is a slight lurch/jerkiness normal if you let the clutch out without enough rpms?
For for grand i think i am just going to get it. How much is a new clutch? Would it be worth it?
Thanks, ryan
Thanks, ryan
Flywheel
Originally posted by spikers400
Ok, well i guess the guy didnt turn the flywheel. How much will u guess that would cost.
SL
For a few years mine chattered when the clutch was depressed because an ID tag inside the heat sheild of the CAT had broken free. It didn't always do it and it was almost impossible to get out without taking off the heat sheild and rewelding it. It was very hard to locate since there are 4 of them and it echoed off the tranny. Even tapping on them didn't duplicate the sound for quite some time. Anyway, I'd definitly look at the CATs before I dropped the tranny. Good Luck on your new truck.
I see what your saying.. But the chatter is more of a jerk, slipping of the clutch. I hear if the flywheel wasnt turned it would be too smooth and the plates wouldnt grab right. And they would slip for a little bit, causing a jerking. O well, ill check it out when i get the truck. thanks
