shift kits
Old Nov 28, 2004 | 02:33 AM
cj1026's Avatar
shift kits
Whats the deal with shift kits. What are they for and what do they do? Do the really work or help anything?
Old Nov 28, 2004 | 09:47 AM
dirtyd0g's Avatar
A good shift kit will shorten the shift duration, cause less slippage, and lengthen the life of the transmission. Make sure you know what you are getting not all shift kits are created equal.
Alan
Old Nov 28, 2004 | 09:54 AM
jpdadeo's Avatar
Old Nov 28, 2004 | 12:42 PM
cj1026's Avatar
How can I find out what trany I have? Its an auto in a 2001 4.6L 4x4. Can you help me figure it out? Thanks for the help.
Old Nov 28, 2004 | 02:40 PM
jpdadeo's Avatar
Old Nov 28, 2004 | 06:05 PM
dirtyd0g's Avatar
Read up on that transgo before you buy it.
there are alot of problems with it.
Troyer also sells the factory tech valvebody.
Alan
Old Nov 28, 2004 | 09:22 PM
cj1026's Avatar
Thanks Alan. I appreciate the help.
Old Nov 28, 2004 | 09:50 PM
dirtyd0g's Avatar
Your welcome
Old Nov 28, 2004 | 10:37 PM
freak98's Avatar
I have the transgo kit in my 98,it did firm up the shift's but I wanted more.So I bought a Superchip's tuner to increase the line pressure and that helped out alot.
Old Nov 29, 2004 | 12:30 PM
BruceScrew's Avatar
I've got the Transgo shift kit in my 2001 Supercrew 4x4 with a Kenne Bell supercharger and I have not had any problems; I've driven the truck very hard too. I have 70k miles on the kit FYI. One of the best upgrades and cheapest too!
Old Nov 29, 2004 | 06:47 PM
freak98's Avatar
BruceScrew,how hard was it to put on the super charger?
Old Nov 29, 2004 | 11:39 PM
dirtyd0g's Avatar
I'm not going to argue with you. All I can say is read this http://www.tccoa.com/articles/tranny/index.html#
then find someone knowledgable on these transmission who agree's with you.
I deal with transmissions and transmission builders everyday. Not all transgo kits are bad. The AOD kit is the best I have found. The 4r70w/AODE kit is the worst.
Don't try to make the mods in that article to a truck transmission. They have a different valvebody and will bang gears hard of you do that to it. That setup is great on cars. Truck valvebodies require parts to be replaced that the normal person can't buy. Gregg Evans is the only person I know with the technology to properly build the truck valvebody. Any company claiming they do has just made at attempt at cloning his.
Alan
Old Nov 30, 2004 | 07:36 AM
BruceScrew's Avatar
freak98,
It took about 10 hours to install the Kenne Bell; one of the easiest superchargers to install. It come with everything you need exept the Denso IT-20 spark plugs (needed for one heat range cooler).
Again, my experience with the Trango shift kit has been very positive. I did have Mike Troyer burn a custom chip for me this year. The combination of the shift kit and chip are excellent.
