Overdrive stopped working!
Old Aug 8, 2004 | 06:19 PM
mg175150's Avatar
The end piece of the shifter on my truck recently broke off. This is the plastic piece with the overdrive button and the overdrive "on/off" indicator. Thus I had the plastic piece with the overdrive wires hanging out of the shifter bar. I pushed the overdrive button on and off to make sure it worked. I could only get the overdrive to turn off after pushing the button several times. I removed the overdrive switch from the end of the shifter. This switch has the end button, led indicator, and 3 prong male connectors.
Has anybody had their overdrive on/off capability suddenly stop working like this? I'm thinking that this switch went bad, and is not something more serious.
The part number on the switch is F58A-76550-AB. Does anybody know where I can find components like this?
Old Aug 10, 2004 | 02:06 AM
Mr_Bentwrench's Avatar
do a search there are alot of posts about those 2 wires breaking in the steering column. and you can get the whole shifter handle and wires at the dealer or a boneyard i supose.
