F150 Manual 5 speed trany question
I have the stock manual trans on my truck and i was wondering when i should start thinking about changing the fluid in it and in the rear axle. I have heard a lot of differnt things, 75k miles, when it needs it (how do i check that? Good sites or books would be helpful as a responce to this) and so on. So im hoping for some pretty straight answers from here on this.
I did my tranny at about 35k, based upon the color of what came out I would say that is about right....it was very simple...it takes less than 2 qts...use a small transfer pump and it take less than 1/2 hour.....two plugs...1 to drain and 1 to fill....no advice for the rear end..... never touched it.... I did notice that some times it was hard to get my tranny in 1st, from reverse...and that went away after the fluid change
Trail boss, what year and model tranny do you have, mine is a 99 f150...mazda tranny.... 1.85 qts I think.... I am due for another change, and plan on using mobil 1 this time....last time I used a synthetic blend. Did you notice any difference
I changed my over to Amsoil fluid at 40K. The stick was noticibly easier to move and smoother. Mine took 3.75 quarts as well. Definitely an important maintenance item. I did the rear end fluid at the same time. Removed differential cover, wiped everything out, reinstalled, removed plug and filled until level with the plug.
Easy work. Take a soft drink under there with you and get comfortable.
Hunt4Fun
Hunt4Fun
wondering about the oil
Is mobile one pretty good for it or castrol ? whats the differnce between those and Amsoil ? I figure if i can spend about 30$ doing both the tranny and the rear i am doing pretty good, but i defently want the best for what i can get. I dont skimp out on anything that comes to my truck if i can avoid it.
My truck is a 99, 4.6, 5 speed I used mobil 1 because thats what they had at auto zone.But I would have used royal purple or amsoil.I did't notice much of a difference after the fluid change.I think its more of preventive maintaince.I will change my rear fluid at 60k or so.My truck is not my daily driver and only put 7k a year on it.
