tranny leak!!
Old Aug 4, 2004 | 04:05 AM
dmmeyer's Avatar
tranny leak!!
Just had transmission fluid changed on my 97 4X4 4.6L at dealership. Now tranny leaks like a SOB. Never any problems before w/78000 miles. Did mechanic do something wrong?
Thanks,
Derrick
By the way, great site
Old Aug 4, 2004 | 11:44 AM
max mitchell's Avatar
Welcome ! Clean it off, find where it's leaking, and compare that to what was done during the fluid change.
Old Aug 4, 2004 | 07:38 PM
dmmeyer's Avatar
Leaking from transfer case. Took back to dealer said its back seal on transfer case. Want 150$ parts & labor. Is that reasonable? Is it likely that it's a coincidence or is the mechanic at fault?
Derrick
Old Aug 5, 2004 | 12:07 PM
I would be immediately suspicious if my tranny started dumping fluid after service. I would find where it was leaking myself, but if it is leaking from where you were told, it has nothing to do with a proper fluid change. The price is high, but appropriate for a Ford dealership.
Old Aug 5, 2004 | 04:34 PM
dmmeyer's Avatar
Thanks Max, appreciate the response. It is leaking ffrom transfer case. Just bad luck I guess.
Derrick
Old Aug 6, 2004 | 11:08 AM
You're Welcome ! Good luck with your repair service.
