Motorcraft Mercon V Also Meets Dextron III
Old Jul 25, 2004 | 09:29 PM
OE812's Avatar
I guess the indy tranny shop was right after all. As indicated in another thread, I purchased 3 containers of Motorcraft Mercon V ATF in the 5 quart container. On the label, it stated
"Mercon V Also Meets Dextron III".
I thought that Mercon V and Dextron III were different? Apparently the Motorcraft Mercon V satisfies Dextron III requirements. Any blue oval mechs out there to substantiate the Motorcraft labeling?
Jeff
Old Jul 27, 2004 | 08:41 AM
Norm's Avatar
That does not mean that you can use Dexron III in a Mercon V transmission however. It may be OK to use Mercon V is a tranny requiring Dexron III but I do not think Dexron meets all the requirements of Mercon V. It might but I would not gamble with my transmission.
Old Jul 27, 2004 | 12:15 PM
OE812's Avatar
I agree. I was just surprised to see that it also meets Dextron III.
jeff
Old Jul 28, 2004 | 02:08 AM
Factory_Tech's Avatar
Just a note about this.
on some transmissions that come with MERCON, it's okay to update it to MERCON V, the AOD-E and the 4R70W are like that, but NEVER, EVER put MERCON V in a 4R100/E4OD.
G
Old Jul 29, 2004 | 11:07 AM
twistedfinn's Avatar
Can anyone confirm that the Mercon V is very close to being a synthetic fluid?
I was told this by a distributor. Never heard that one before...
Old Jul 29, 2004 | 12:57 PM
casey_1's Avatar
It depends on what you get.
The factory MERCON V is a synthetic blend. There are MERCON V fluids available in conventional, synthetic blend, and full synthetic.
