M5OD strength?
Old Jun 1, 2004 | 03:47 PM
droptail's Avatar
M5OD strength?
How would this tranny hold up to a 5.4L S/C duty, if it wasn't abused at the stop light? Would it bolt up? What is its torque rating? Is there a way to strengthen it?
Old Jun 3, 2004 | 10:04 PM
thesource's Avatar
The transmission will take some power and torque . I don't think it would be a good choice in a large truck such as a F250 but would be killer in a 1/2 ton with a 5.4 and a power adder .
As far as making it stronger , there are no after market parts that will make it stronger but the factory stuff is pretty good . I would put it up against an Automatic any day .
Mike
Old Jun 3, 2004 | 11:06 PM
Coupef150's Avatar
I have a M5OD in my 2002XL 4.2 RegCab 4x2. I'm not a big fan at all. The master slave assembly is very unreliable. Mine blew at 23,000 and they tend to do a repeat act. They are very prone to air and moisture in the line and have to be bled often. It is a long throw shifter it is soft and is not good for racing. In addition the synchro's are known for not meshing well. I have a problem with mine in first and third. Don't know why Ford uses this tranny I would have been happy as hell with a good old cable clutch like a Tremec.
Old Jun 7, 2004 | 05:42 PM
JMC's Avatar
JMC
25 Year Member
Ford should have gone to an external slave. As for the tranny holding up to any power. Forget it. You will be picking up parts sooner than later. I am making about the same power as a 5.4 and I am on my second tranny. My truck weighs about the same as a 2wheel drive SD. I would love to get a better tranny but t he only option is a ZF from a Super Duty. Untill I lifted the body 3 inches there was not enough room to fit it.
JMC
