Clutch pedal stayes on the floor
Hello
I have a 1990 F150 st6 5 speed. It sat for close to a year with little maintenance on it and only started a few time. The clutch was replaced about 3 years ago and was working fine before the truck was stored. Now the clutch pedal stays on the floor board. You need to use your foot to bring it back up. Everything shifts fine. I can shift into all gears no problem. At some points the clutch does come back up but not to often. What should I be looking for with this kind of issue. It makes no noise when I press it in. The fluid is also ok. Any help would be great Thanks for your time in this matter
Lanai00
Lanai00
Re: Clutch pedal stayes on the floor
-Brad
