Grease for Front of Drive Shaft
Old May 21, 2004 | 10:17 PM
thompsdw's Avatar
Does anyone know what grease is recommended for the sliding end (front) of the drive shaft where it attaches to the transmission? My shaft popping has gotten to the point where I have to grease the joint.
Thanks for any help in advance.
Old May 22, 2004 | 11:44 AM
max mitchell's Avatar
Ford teflon grease D2AZ-19590-A
Old May 22, 2004 | 05:46 PM
Roadie's Avatar
If you don't ever want to grease the tailshaft again, go to tccoa.com and read the tech article there about installing a lube line to the rear bushing. If you do this the problem will be forever solved. The article is written by a former Ford transmission engineer.
