vibration in the rear
Old Apr 13, 2004 | 11:06 AM
goldiemack's Avatar
i have a 1998 f 150 auto. when i take off to turn, i get a vibration. it only happens when i turn and only when shifting from first to second. any ideas?
Old Apr 13, 2004 | 08:23 PM
max mitchell's Avatar
Welcome ! Do you mean this sound occurs when you accelerate from a dead stop, turning a corner? Where do you feel the vibration coming from? Is there a noise to describe? Do you have a limited slip rear end and has it been service? What mileage is on your truck? Is your 1st to 2nd shift quiet and smooth in every other circumstance.
Old Apr 14, 2004 | 12:30 AM
goldiemack's Avatar
yes. it only happens from a dead stop when i turn. i ordered some friction modifier. will that clear up the prob
Old Apr 14, 2004 | 12:37 PM
Well, you didn't answer my questions, so, I don't know. There are some very qualified drivetrain experts here that can probably help. My first guess was that IF you had a limited slip rear end, then your LS clutches were chattering a bit. Hence, I wondered if you had regularly serviced your rear end. Based on that, you could need a simple gear lube change and properly measured friction modifier. I asked mileage because if you had a high mileage, poorly service, limited slip rear end, then, you could have a worn clutch pack. Go back and try to fill in some of the answers and I'm positive that someone here can help you.
Old Apr 14, 2004 | 11:06 PM
5.4MAN's Avatar
Account Suspended For 14 Days For Terms of Service Violations
yea i did a quike search for vibration in the rear and came up with maxie he the guy to ask!!!hehehehhahahaahhehehehehehahahahahahahahhehe hehehe
Old Apr 14, 2004 | 11:40 PM
GrandmaF150's Avatar
goldiemack,
I have the same problem too. This happens when I make a turn from a dead stop. I do not have the problem when I shift from 1st to 2nd gear. My truck has 122 K miles on it. I have no idea when it was last serviced. It is hard to say where the vibration comes from. It could be from the wheel hopping.
