Transmission range sensor/brake probs
Old Apr 7, 2004 | 05:30 PM
dbag's Avatar
Exclamation Transmission range sensor/brake probs
The sensor on top of my master cylinder had a melt down today. It actually was melting. I bought the $30 part from the local dealer and installed it. Now my ABS lights came and I cant get it out of park while its started or the key in the on possition. My brake lights quit working too. WTF. Anyway. I replaced the sensor on the cylinder, tested the wires and connectors to that sensor and brake switch connected to the brake pedal. All tested fine with the multimeter. I have to turn the key forward 1 position to put it in nuetral to start it then I can drive and shift into any pos no prob. If I go to park, it wont come out of park and I have to repeat the process I just talked about. I have to drive it home from work without brake lights now. Any body got any suggestions? Help.
Dan
97 F150
Old Apr 8, 2004 | 04:01 AM
Mr_Bentwrench's Avatar
the brake light fuse is blown
this fuse also affects cruise control, ABS, and the brake shift interlock.
i cant recall what blows the fuse but if you run a search here i have read about it before. i think it might be thats brake pressure sensor that shorts out and since you already replaced that now just find that blown fuse.
