O/D button pushed, dash goes dead
Old Feb 29, 2004 | 01:31 PM
bmarkul's Avatar
When I pushed the O/D botton on the gear lever, the dash went limp. All guages, and lights do not work. Any suggestions.
Old Feb 29, 2004 | 11:23 PM
adaycj's Avatar
Check fuses, check for common ground.
Old Mar 5, 2004 | 01:57 AM
AjRagno's Avatar
bmarkul,
If you haven't figured it out yet, the wires inside the shift lever, leading upto the O/D switch have frayed. When you pressed the O/D button, the switch received power and the exposed wire shorted the circuit. The O/D swith and instrument cluster use the same fuse.
You may or may not need to remove the steering column cover to find the exposed wire.
The Fix
