trans shudder
Old Feb 19, 2004 | 05:35 PM
Droftruck's Avatar
So I turn the motor over until the plug from the converter is on the bottom and I can drain it. I pull the pan and the gasket and filter out and replace them. When I fill the transmission after reassembly will the converter also fill?
Old Feb 20, 2004 | 10:15 AM
Whitetrash SVT's Avatar
Not until you start it...it'll take a few minutes to charge, and may not charge completely until after a road test. Make sure you check it after a drive. It should hold about 12 quarts when you refill it.
Old Feb 20, 2004 | 05:06 PM
Droftruck's Avatar
Jim - Thank you so much for the help! Do think it is necessary to change the fluid in the torque converter??? Does the torque converter fluid circulate through the entire transmission?
Thanks again
Larry
Old Feb 21, 2004 | 12:55 PM
Yes and yes.
Old Mar 12, 2004 | 04:45 PM
Droftruck's Avatar
Nice job Whitetrash. Smooooooooth.
