E40D Transmission Problem
Old Jan 14, 2004 | 04:41 PM
Flash24's Avatar
I have an 88 Ford F-150 with an E40D transmission. I started having problems with it a few days ago. When O/D is engaged, it slips when shifting into O/D. When O/D is disengaged, it won't shift out of 2nd gear and will only run 45-50 mph. I took it to a transmission shop and they said the fluid looked ok and they dropped the pan and there was no metal shavings. But they told me it needed to be rebuilt. I had the fluid and filter changed about a year ago. The truck has 180K miles on it. If my fluid isn't burnt and I have no metal, do I really need an overhaul or could there be another problem? Please Help!
Old Jan 14, 2004 | 09:27 PM
Factory_Tech's Avatar
It needs to be rebuilt, sounds like the Direct Clutch plates are burned up to me, but there are several thihngs that can cause a failure without breaking any hard parts and leaving metal in the pan, with that many miles, it likely needs an overhaul.
G
Old Jan 15, 2004 | 03:52 PM
Flash24's Avatar
Thanks for your help!
