Tranny down shifting
I'm having a problem with my 1997 F150 4.6L auto trans. When I am slowing down to stop for a light and the light turns green or slowing to make a turn it shakes, the trans acts like it did not down shift. I can give it more gas and it seems ok. If I come to a complete stop and take off it shift fine. I have changed the fluid and filter.
Did this start right after your fluid change? Check your dipstick and see if it required Mercon V, and if so is that what you used? DextronIII and Mercon aren't good enough.
If that's not it, sounds to me like there's some dirt in the valve body perhaps plugging one of the separator plate orifices.
What happens when you manually downshift at the column shift lever?
I picked the truck up back in June and have noticed this ever sense then. I changed the fluid and filter about a month ago.
I have been changing all the fluids and gear lubes(112,000) on the truck. I noticed a sticker on the side of the bell housing stating a rebuild date. I did not look at the sticker real close.
There has been no change. I did use the Mercon fluid that the manual called for.
It shifts thru all the gears fine, both manually and on it own. The overdrive works fine also.
