'86 4spd AOD swpped to '70 C4??
I have an 86 xlt with a 302 converted to carburation. anyway once i got it going I found that the tranny is pretty well shot and slipps really bad. I have a 1970 C4 that I was thinking of putting in it. the question is, does anyone know if there is a difference in length, spline count, and possible gear ratio difference between the AOD and the C4(1st-2.46:1 / 2nd-1.46:1 / 3rd-1:1) any info would be appreciated. thanks
Shane
Shane
I'm not sure if this will help voodoo. This is an article about a swap from a C4 to an AOD. But I think it will explain alot of the within each type of transmission.
http://www.mustangsandmore.com/ubb/D...C4AODswap.html
HTH
HTH
Hey thanks alot, that does help alot, you dont by any chance know what the stock rear is on these trucks? OH and I noticed your from wichita KS. I am a Wichitan also. hopefully I will try to get that tranny swapped this weekend. I think the rear is pretty low geared so I wont be doing much Hgwy drivin. thanks again
Shane
Shane
I don't know what the stock ratio is for your truck. If you give me the code off the sticker on the door jamb, I can look it up. If it still has the original rearend in it, then the tag should still be on it.
