Will Bigger Tires = Transmission Issues
Old Jul 8, 2003 | 07:05 PM
ch51670's Avatar
Unhappy Will Bigger Tires = Transmission Issues
I just put 16X10 wheels with 315/75 tires on my 2002 fx4 supercrew 5.4L. Will this create transmission problems?
Please respond, thanks!
Old Jul 8, 2003 | 07:22 PM
AjRagno's Avatar
You'll may want to have the computer reprogramed. The dealer can do this, or you may even be able to use a Superchips Micro Tuner. Although you may not absolutely need to have this done, the speedo is off and the transmission RPMs are lower than what the transmission and engine are currently programed for.
Original tires were 265/70R17=31.61 inches
New tires are 315/75R16=34.60 inches
Old Jul 8, 2003 | 09:00 PM
01 XLT Sport's Avatar
AjRagno makes good points. If it were me I would leave it alone because you will get a longer warranty this way...
Bigger tires, record fewer miles then has actually been driven.
Old Jul 8, 2003 | 10:49 PM
ch51670's Avatar
thanks for the responces. how easy and at what price will it cost me to program it myself. would it be easier to have the dealer perform the reprogramming? if i leave it alone will my tranny be negatively affected?
Old Jul 9, 2003 | 08:49 AM
Tiger's Avatar
With normal maintenance your tranny should be fine. Get a Superchips micro tuner and you can reprog the speedo and get a juice boost to boot.
Old Jul 12, 2003 | 03:07 PM
JMC's Avatar
JMC
25 Year Member
ch,
The Dealer will not be able to reprogran as the tires are not within the programmable parameters. What tires do you have now 315/75 17? What were the OEM tires? 265/70 17? If that was so having the dealer cheat by programming 255 70/16 with 3.08 gears will get you close to what it was. from the factory.
Regards
Jean Marc Chartier
Old Jul 12, 2003 | 04:34 PM
ucfperspicere's Avatar
I've changed tire sizes twice on my truck. The first time I went smaller, so I had the dealer reprogram it (I didn't want to be logging extra miles). I'd already had my transmission blow, too, so I had extra incentive.
Last September I went back to tires closer to stock size. I drove it without reprogramming for a couple months and enjoyed only logging about 90% of my miles. I've since found out, however, that this is technically odometer fraud. I didn't have any tranny problems during this time (no more than normal, anyway), but the speedo being off drove me to finally have the dealer reprogram again.
The dealer charged $90 each time. After spending $180 on having the dealer do it, I wish I'd have put that $180 toward a Micro Tuner. But hind-sight is 20/20. If you have the money, I'd recommend buying the tuner. You can get it from Mike's site TroyerPerformance.com.
Good luck.
