Jumping Transmission
Old Jul 1, 2003 | 08:59 PM
Droftruck's Avatar
I have just begun experiencing some jumping in my 99 F150 4x4 4.6L. Normally this happens when I am at a low rpm with the automatic transmission shifting from 2nd to third (going up a hill). I have not experienced this with a higher rpm. I also hear a click underneath the truck when I am slowing down from about 25-30mph to a stop. Could this be a sensor??? I have never towed anything with this truck and it has about 45,000 mi. Thank you for your help.
Old Jul 1, 2003 | 11:22 PM
only one's Avatar
Don't know if this helps, but have you checked your fluid level lately?
Old Jul 2, 2003 | 04:57 PM
Droftruck's Avatar
Yes it's fine. Thank you tho.
Old Jul 8, 2003 | 11:04 PM
capp106's Avatar
reply...
my 1997 started doing the same thing (slight chattering vibration). it was noticed the most when going up a hill or bridge just before downshift. i took mine to the local atlas transmission shop and had the transmission serviced including all the fluid and filter. the problem went away. about a $70.00 fix, not bad for the normal repair prices of today.
i hope this will help, it surely did for mine,
mike
